changes in secondary controller
suthomas1
Level 7
Level 7
If two controllers are in ap sso high availability mode, how do we do changes in the secondary backup controller.
Consolling in to the secondary doesn't allow any changes. Is there any command from primary that is used to config or change parameters on the secondary controller.
Thanks in advance.
Well you will have to disable AP SSO and make your changes and then enable AP SSO again.
-Scott
Scott Fella
They are sync'd and therefor you make changes only to the primary WLC that is active and the changes will be pushed to the HA WLC.
-Scott
what if i want to change the hostname for controllers, that includes the secondary controller also.
thanks in advance.
-Scott
