Changing SSID with Radius Attributes w Controller
Hi All, following Scenario: Customer wants to Broadcast one SSID, within authentication against Radius (Free Radius) the User should be moved into another, not broadcasted SSID with a separate Security Policy. Is such a scenario realisable? I know that it is supported in IOS based Implementation, called SSID-IE. Regards, Michael
wong34539
Level 11
Level 11
When you create an SSID in global configuration mode, you can assign or change the SSID attributes only in global configuration mode. Similarly, when you create an SSID in configuration interface mode, you can assign or change the SSID attributes only in configuration interface mode. Refer to the following URL for creating SSID
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a0080341d5f.html#wp1017196
Stephen Rodriguez
Yes, you need to set the attribute pair in the AAA server, I believe it's 80 and 81. When you set this, you need to use the name of the vlan, not the number.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
