Changing the key index of Cisco Aironet 802.11abg
RobertDWhalen
Where do I go in order to change the key index value using the Cisco Utility for the AIR-CB21AG-A-K9
dsweeny
Level 3
Level 3
You have to go WEPDOS.EXE for change the Key index value for aironet.
Syntax - WEPDOS [-tx#] [ascii] [hex] [-key#] [home] [-d]
http://www.cisco.com/en/US/docs/wireless/wlan_adapter/350_cb20a/user/ms-dos/configuration/guide/DosUtilities.html#wp1004918
