Channel assignment in 802.11a mesh configuration with 1552S APs
Can anyone suggest what should be the channel assignment for RAP(s)\MAP(s) in a 802.11a mesh metwork. Whether it has to be Global or Custom? Which option is more advantageous or feasible?
Why Tx Power Level Assignment can't be assigned as Global in a mesh configuration? Is RRM not supported in mesh configuration?
I will be grateful to anyone who answers these questions.
Kiran Shivaramaiah
pieterh
I would go for: set it to global and after initial assignment set it to "freeze" and have this updated manually
Step 3 Choose one of the following options from the Channel Assignment Method drop-down list to specify the controller's DCA mode:
•Automatic—Causes the controller to periodically evaluate and, if necessary, update the channel assignment for all joined mesh access points. This is the default value.
•Freeze—Causes the controller to evaluate and update the channel assignment for all joined mesh access points, if necessary, but only when you click Invoke Channel Update Once.
Note The controller does not evaluate and update the channel assignment immediately after you click Invoke Channel Update Once. It waits for the next interval to elapse.
•OFF—Turns off DCA and sets all mesh access point radios to the first channel of the band, which is the default value. If you choose this option, you must manually assign channels on all radios.
from the same guide (RRM is supported)
In addition, the radio resource management (RRM) feature enables cell breathing and automatic channel change, which can effectively decrease the collision domains in a mesh network.
Pieterh,
In a 802.11a mesh configuration when RF backhaul channel assignment is configured as "Custom" as recommended by Cisco, how does DCA works?
same document section: Configuring Power and Channel Settings
The backhaul channel (802.11a/n) can be configured on a RAP. MAPs tune to the RAP channel. The local access can be configured independently for MAP.
-> for clients ("the local access") DCA works separately from backhaul channel.
also look at the section: Backhaul Channel Deselection on Serial Backhaul Access Point
as for how backhaul channel DCA selection works.
