Check antennas status AP 1252 in lower power mode
Hi all, I want to know how can I check the status of antennas of AP 1252 in lower power mode.
My customer has not yet the POE Plus switches so the AP can not make the most of use of all antennas. AP 1252 has 3 Rx and 2Tx antennas but it does not use all of them because it has not POE plus.
How can I see the antenna that are up? With the following command I can not get it: "show controller dot11 0". It only shows that AP is running in lower power mode.
Thanks by advance
Fernando
Leo Laohoo
Hi Fernando,
Upgrade the IOS to 12.4(10b)JDA3 (or later) and the 1250 should be able to operate both radio modules at 15.4w.
