Checking memory and CPU in access points AIR-CAP1532I-A-K9
pablomunozrojas
We have AIR-CAP1532I-A-K9 access points managed from a Cisco Flex 7500 WLC.
By means of snmpwalk to the WLC and using the mib file "CISCO-LWAPP-AP-MIB" and the iod "cLApCpuCurrentUsage" and "cLApMemoryCurrentUsage", we consult the use of the memory and the cpu of each administrator AP by the WLC.
The problem that the results of each query gives a value of zero (0).
Will there be any restriction or rating that must be done in the AP or WLC to obtain real values?
radam
I have the same issue and the OID you have mentioned, sadly it does not help. The OID only keeps the value that you configure, when the AP should send a trap if the defined value by you (OID is read/write and percentage) is reached. You can not poll the OID to see the CPU usage.
I am also looking for a solution to monitor the AP CPU...
If you have prime, you can set it under Monitor > Monitoring Tools > Monitoring Policies > Automonitoring
-hope this helps-
