09-01-2015 08:21 AM - edited 07-05-2021 03:51 AM
Hi everyone,
I have few external antenna for few 1252 AP's need to know should i connect them to 2.4 GHZ or 5.4GHZ?
Its for internal use inside the building.
Also i have one AIR ANT2430V-R need to if i put 1252 inside the ceiling then users can connect to AP via Signals from AIR ANT2430V-R?
Mahesh
Solved! Go to Solution.
09-02-2015 11:44 AM
That antenna is for 2.4ghz only:
http://www.cisco.com/c/en/us/td/docs/wireless/antenna/installation/guide/ant2430v.html
You would need a 5ghz antenna if you want to use the 5ghz. Here is Cisco's antenna reference guide
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
-Scott
09-02-2015 11:46 AM
Here is one that has both bands: AIR-ANT2451NV-R=
-Scott
09-02-2015 11:44 AM
-Scott
09-02-2015 11:46 AM
-Scott
09-03-2015 07:32 AM
Many thanks Scott
MAhesh
