Cisco 1130 AP connection speed?
licopeland
What speed do Cisco 1130AG access points connect to the network via the Ethernet port? Is it a 10/100 connection or does it support gigabit? I've searched and can't seem to find this information. Thanks!
The 1130 data sheet lists the uplink port as:
Autosensing 802.3 10/100BASE-T Ethernet
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6087/product_data_sheet0900aecd801b9058.html
Leo Laohoo
Hi Lillie,
If you want an AP with 10/100/1000BaseTx copper uplink then 1140 or 1250 is your way to go.
Data Sheet Cisco Aironet 1140 Series Access Point
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html
Data Sheet Cisco Aironet 1250 Series Access Point Data Sheet
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c5c.html
If you are going to choose the 1250, note that the Antennaes are optional. Here's some information regarding them.
Antenna Product Portfolio for Cisco Aironet 1250 Series Access Points
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
The AP1250, when operating with 2 radio modules on Autonomous IOS, requires a minimum of 18.5 watts (ePoE). So you'll need either a Power Injector or PoE switch that will support enhanced PoE such as the 3560-E or 3750-E.
802.11n Design and Deployment Guidelines
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
Hope this helps.
