Cisco 1252 POE+ not working with Juniper EX2200
johnschwoerer
We bought a Juniper switch that supports 802.3at in hopes of powering Cisco 1252 ap's.
Cisco 1252 ap and EX200 are not negotiating to the higher power.  Juniper thinks that the 1252 is running pre standard poe and will not work correctly with the juniper switch.
Anyone run into this before?
Leo Laohoo
On the 1252, give this series of commands a try:
1.  Enter the command "power inline negotiation injector installed".
2.  You'll get a message with  a MAC address in the end.
3.  Copy that MAC address and run the second command "power inline negotiation injector ".
Hope this helps.
