01-20-2012 04:44 PM - edited 07-03-2021 09:25 PM
We’re deploying new WIFI towers at several of our vacation resorts and have decided to migrate from Wireless G to Wireless N access points.
We currently have the following in each WIFI tower – Hotspot
1 x 25mbps/5mbps circuit (inside air conditioned shed)
1 x Cisco 881 router (inside air conditioned shed)
3 x Cisco 1310 AP’s (inside air conditioned shed)
3 x Luxul Wireless - 2.4 GHz, 1 Watt Outdoor Amplifier (inside air conditioned shed)
1 x 25 foot three pillar antenna mast.
3 x 30 foot TNC cables
1 x PCtel 2.4 GHz ISM All Terrain Sectorized Omnidirectional Antenna (offset 5-10 deg down )
I’ve been researching and speaking to our partner pre-sales team, and have narrowed the choice down to deploying 3 x AIR-AP1261N-x-K9 at each of our towers. I have been unable to find suitable replacements to the 1watt Luxul 2.4ghz amplifiers we’re using, or really good N sector antennas to mount to the top of our masts.
The 1260’s are all 802.af, so besides getting power injectors there shouldn’t be to much to think about.
Do any of you guys/galls have any suggestions for suitable N sector antennas , or suggestions?
Is there specific antennas I can use to utilize the 2x3 MIMO feature of these AP’s?
01-20-2012 10:36 PM
1261? You sure about the part number? You do know that the 1261 only has ONE radio, 802.11b. With one radio, it will only do half of the data rates of 802.11n.
Next, your antenna, I'm not familiar with those.
The location of the WAP should be in the middle of your clients. It's not recommended to use a dipole or "disco stick" in one corner of the area you want coverage.
01-21-2012 08:43 AM
Not entirely.
After reading through these forums and looking at more product material I'm not sure any longer what we're going to need.
I'll run over to one of the resorts today and take a couple pictures of the equipment/towers so you can see what we're doing.
For the moment being - here is a quick map I just created for a rough example of a propertiy with our current wireless G towers in red. approved N towers in yellow.
We did site surveys for the past couple days at all of our properties and had the meetings/approvals to place 2 more new towers at a handful of resorts. What I would really like to do is 2 or 3 1550's at each tower paired with a 2504 WLC controlled by Cisco Prime Network Control System at our office on a 50in LED.. That was shot down in flames!!
The clients are only willing to use standalone AP's, but these resorts are in Arizona, so they need to be rugged to support the extensive heat of the desert. It helps we have all of the equipment inside a dedicated air-conditioned shed at each site. But the lack of options with the Wireless N Aironet products are confusing me:
1260 - support up to 6dbi external antenna’s
1550 - Lightweight only..
Suggestions?
This is the Omni direction antenna's were using right now.. They're pretty sexy, and would like to keep the same type/kind of 90deg sector coverage (or better)
Thank you very much for your reply. I welcome any critique, comments, or suggestions you can offer..
01-21-2012 02:59 PM
OMG! I've never seen a resort this HUUUUUGE before! Is the resort construction finished yet? If not then your wireless site survey is as close as useless. If the wireless site survey was done AFTER complete of construction and after furnitures and fixtures are in place then you have an idea. But I am unable to determine the area of this resort.
Another thing ... 802.11N and a 2504???? Are you sure? The WLC 2504 may be very affordable but all I can say is it's not scalable because the ports are FastEthernet. You need to have a controller with GigabitEthernet like a 5508.
I have a few questions:
1. What is the height of the antenna? If your antenna will be installed higher than 10 metres up in the air, then forget about wireless. It won't work effectively.
2. You only have 2.4Ghz. This will not give you FULL 802.11N. This will only give you the "low fat" 802.11N. For full 802.11N you need to have both 802.11a and 802.11b radio.
3. CleanAir, do you need it? Do all these rooms have DECT wireless phones or microwave oven or other wifi/wireless products. If the answer is yes, then I believe you and/or your setup should consider CleanAir WAPs. The 3500 and 3600 are good candidates. The 3600 was released last November 2012 and it supports 4 x 4 MIMO while the 3500 supports 3 x 3 MIMO.
4. Antennas - Don't be mislead by the -6 dBi limit. Remember that the wireless medium is a two-way-street. If you have a very-high-gain antenna on the WAP side then this is akin to shooting wireless signal downrange and at a long distance but the WAP will not be able to "hear" the signal coming from the client. You only use very-high-gain antenna when you intend to implement point-to-multipoint or point-to-point wireless bridge.
5. Wireless is also a shared medium. Think of a WAP as a "hub". When one talks, everyone else has to stop, listen and waits for their turn. If you have a lot of chatter then chances are you'll get congestion. Cisco recommends no more than 25 clients associate to a WAP. This value of "25" also depends on what kind of traffic is flying around. If you, say, are talking about emails and surfing the web, then this value can go up to 30 but if you are talking about non-cached, video streaming then that value can drop to about 5 clients per WAP.
Apologize for the long response. Shouldn't have coffee when I wrote this.
01-21-2012 06:40 PM
That's just one of our parks, and yeah, their pretty big. These parks are stuffed with single wides, double wides, RV's of all shapes and sizes and is in full bloom right now with the warm winter we're having (full capacity). So, inharently everything's made of metal, has a microwave oven.
I've been saying for a while that out current towers are pushing the G signal WAY to far becasue the compliant devices 300+ feet away, and often seen upto 1000 feet away with strong signals have absolutly NO chance of comunicating with our towers. But old retired people don't really care, they think that if they recieve a 5bar or 4bar signal they should be within range of our hot-spot towers. Whatever..
I'm almost 100% possitive the 2504 is giagbit. It's the cheapest WLC that is designed for the 1260 & 1550's. But that's all besided the point. I would love to do things my way, but I collect a paycheck just like everyone else.
1. The Antannes are on top of these towers. They're tall - 30 feet/9.144 meters. I know the E plane of normal wifi adapters inside laptops and mobile devices suffer drastically trying to communicate with our towers due to the height and I have brought this to attention. There is just so much I can do about it at the moment. Hences - new N towers...
2. I would LOVE to keep our 2.4ghz G wifi isolated from these new tower and not allow backward compatability to a/b/g. I would LOVE to make the new N AP's fully N complient and effecient as possible. If that requires buying several radio's per AP, or only special equipment that's what I'm willing to do.
3. We have an immense issue with interferience throughout these parks. The resident spots are cabled for CenteryLink or Cox and 20%+ have their own WIFI inside their RV's or park model homes. Durring our surveys I noticed some locations with overf 30+ SSID on top of our towers. It was silly..
4. Agreed. with 1260's and their 3 available TNC antanne connections I absolutly want to place these new antannes closer to the middle of these towers. In some locations at diffrent parks there are no sutable spots to add new tower locations and will be force to stack antanne's on our tripple pole masts. 2.4gh at the top and N - 5ghz antannes mid mast.
5. Agreed, half-duplex, 25 mac-address associations, that's why we have 3 x AP's at each tower.
how would you suggest I deply a standalone N multi 1260 AP tower? how many radio's, antenna type/size, location on our the towers, etc..
Drink 2 more cups - you're awsome!
01-21-2012 07:03 PM
Yes the 2504 has a gig interface but the actual data backplane maxes at 300Mbps.
Honestly CleanAir isn't going to do much for you in this environment, it will only inform you what you already know.
I would look towards a 3600 simply for the 4x4 antenna. But you need to get smaller cell sizes and have the AP mounted lower.
01-21-2012 07:16 PM
RV??????
Oh geez. Microwave in every RV? Great. When someone gets hungry then there's a fair chance your 802.11b/g goes out the door. There are some good ovens which operate in a limited frequency but there are some which operates in the full 2.4Ghz spectrum. There's a news article I read about a retired couple who owns this very, very old TV. Everytime they turn on their TV to watch the afternoon show, the wireless in that block goes out. The mobile phone provider couldn't determine or replicate what they are seeing in the lab. The mobile phone provider had one recourse left: The retire was told by the phone provider to look for a TV of their choice and they were handsomely compensated. Problem solved!
Anyway, back to your issue ... Antennas should not be installed higher than 10 feet from the ground. The WAPs and/or antenna, in my opinion would be situated, for example, between 2289, 2185, 2287, 2186. This way there's minimal chance of the pole/post to be run over by the RV.
Range and coverage, if your plan is as accurate and it's a flat location (like a parking lot), then I'd take the position I'd mention above, along with a compass and draw a 20 feet radius. You will get further more than that but you have to consider the fact that you need your wireless signal to penetrate INTO metal surfaces and that is going to be a ba$tard to nail.
Antennas transmit and receive radio signals which are susceptible to RF obstructions and common sources of interference that can reduce throughput and range of the device to which they are connected. Follow these guidelines to ensure the best possible performance:
Install the antenna vertically and mount it with the cables pointing towards the ground.
•Keep the antenna away from metal obstructions such as heating and air-conditioning ducts, large ceiling trusses, building superstructures, and major power cabling runs. If necessary, use a rigid conduit to lower the antenna away from these obstructions.
•The density of the materials used in a building's construction determines the number of walls the signal can pass through and still maintain adequate signal strength. Consider the following before choosing the location for your antenna:
–Signals penetrate paper and vinyl walls with little change to signal strength.
–Signals penetrate only one or two solid and pre-cast concrete walls without degrading signal strength.
–Signals penetrate three or four concrete and wood block walls without degrading signal strength.
–Signals penetrate five or six walls constructed of drywall or wood without degrading signal strength.
–Signals will likely reflect off a thick metal wall and may not penetrate it at all.
–Signals will likely reflect off a chain link fence or wire mesh spaced between 1 and 1 1/2 in. (2.5 and 3.8 cm). The fence acts as a harmonic reflector that blocks the signal.
•Install the antenna away from microwave ovens and 2-GHz cordless phones. These products can cause signal interference because they operate in the same frequency range as the device to which your antenna is connected.
You're right about the 2504 with a Gig interface. My apologies for the confusion.
I'd consider the 3500 or the 3600. With CleanAir, whenever interferrence occurs, the WLC and WAPs will independently change the channel. The 1260 can't do that.
01-21-2012 07:19 PM
The 2504 do have Gig ports, but they are not capable of Link Aggregation (LAG), so you cannot do multiple uplinks without doing different interfaces. You could do HREAP which alleviates some of the bottleneck.
Higher gain antennas do/will help with client reception as they contribute to receiver sensitivity, which is part of the link budget. As these are indoor APs, it is difficult to find higher gain antennas due to FCC requirements that the antenna connectors must comply with regulations.
Also note that the number of clients and the range of clients will depend on the data rates you allow. The lower the data rates you allow, the further the client can move from the AP, but fewer clients are able to be serviced by the AP.
With 802.11N I've seen up to 75 clients on a single 802.11a/n interface, but it all depends with how much per user bandwidth you want to allow for, and how big the cell is going to be.
01-21-2012 09:32 PM
I don't really care about the FCC, If I could find power amplifyers for wireless N simular to the 1 watt Luxul amps were using now I'd buy them.
So, how about this for each location:
3 x Cisco 3602 WAPS - AIR-CAP3602E-x-K9
3 x Cisco MIMO 6db antanna (mounted to each side of the 3 pole mast) - R-ANT5140NV-R
3 x 15 foot RP-TNC cable from WAP to antanne
Mount the 6dbi 15 feet up the mast - (most RV's living spaces are 5 feet off the ground)
Mount the 3602's inside the airconditioned shed - run the 15 foot PT-TNC cable up the mast to antanne.
Configure the AP's to sellect the best channel and walk away (besides obvious config needs)
I can set these 3602 WAPS to use 5ghz only leaving the 2.4ghz G towers off possible interference issues?
EDIT: Wait, the 3500 and 3600's are all controller based.. I need standalone.. sigh...
EDIT # 2: How far will these 6dbi Cisco R-ANT5140NV-R antanne's propigate a usable signal?
01-21-2012 10:35 PM
3600 are two-in-one, i. e. each antenna can support both 802.11a and 802.11b. Therefore you need to look at this file:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
The antenna for the 3600 is located on the last page.
I thought you were also looking at the WLC2500?
You can disable 802.11b low speed rates. Take note that not all clients support 802.11a. There are some old devices (like iPhone 3, for example) that's only 802.11b.
01-21-2012 10:50 PM
Ummmm ... The 880 router is rated at 25.60 Mbps. This value is expressed in HALF duplex so which is less than 13 Mbps. The 890 is rated at 51.20 Mbps and this does not leave you any room for the expansion or increase of your bandwidth. Is your WAN link set in "stone"? Do you plan to upgade to a higher bandwidth if, say, business is good?
01-22-2012 07:37 AM
In no particular order:
I've been useing the 851, 871 and 881's with great sucess. This past month I've bumped up 30 of our WIFI towers to 25mb/5mb. Our CFO wanted to do 80mb/10mb, but due to the speed limitations with G, I chose 25mb instead. For these new towers I'm comfortable getting the dedicated 80mb/10mb circuts to utilize N speeds.
I've had really good sucess with the packet per seconds speed of these little routers. Even the older 1800 series we used were more then able to handel 50mb circuts. The links are never heavely saturated, I've done some NBAR packet inspection from time to time and it's pretty low..
The 881 is just what I'm useing for the G towers combined with 3 x 1310's. I've had good sucess with the new 1921's, One guy I know is using 1921's on 100mb circuts.
Not doing 2504 WLC - That was shot down in flames - The WAP must be standalone. I pushed for it with ceneralized network manengment software at our office where we could manage the towers like a NOC on a large LED TV but, thats not going to happen..
Thanks for the Antanne Link - That data sheet is where I discoverd the 1260's can use only 6dbi antannes. Because I "must" have standalone WAP's, pretty much limiting my sellection exclusivly to the 1262 it seems like the only reall antanne sellection is 3 x AIR-ANT5160V-R per 1262 wap..
Thoughts?
01-22-2012 01:27 PM
Ok, no WLC. So this rules out 3500 and 3600.
This leaves you with the 1260. Now you chose the ANT5160. This is OK as it falls within the supported limit of the 1260. What protocol did you base your site survey on? 802.11a, I hope.
I'd ask you to (re) consider the use of the 802.11b as I distinctly remember some clients (iPhone 3, laptops) that only has 802.11b/g radio.
No WLC? So you don't really need the Prime NCS box?
My opinion is, and I hope you and management don't take any offense, is to start the implementation on a gradual basis. Find a central location and start with one. This is based upon your budget. When word gets out that your wifi is better than each of these RV owner's personalized one then they'll line up in your adminstration building asking to be "let in". This way, you have a good indication (and demographics) as to know whether or not your wifi is going to take off quickly or slowly.
01-22-2012 06:18 PM
thats, not much of a concern, all of these parks are under the same ownership and resort name.
Everyone of the current WIFI towers we have up right now are configured b/g mixed mode, and will stay that way for a long time. I'm planning on stacking N on the same towers eventually halfway down the masts this summer.
Nope, the NCS box was only on the agenda if I could get the WLC's approved.. It's still possible - but not until we get the initial towers out of the way, I'll continually work on them for this. I dread "wifi's down" phone calls. Having a NCS box would make life SOO much easier..
The Cisco literature says I need 3 x ANT5160's per 1262 wap. I'm very unsure how that translates into installation/deployment/mounting locations.. Where would I learn more about this and how would that effect wanting to mount 3 x 1262's making a total of 9 x ANT5160's at each tower?
Is there a good book you can recommend from Cisco that will help me as I get this going?
As always, I greatly appreciate your assistance!!
01-22-2012 06:28 PM
That's correct. This is for diversity and part of the MIMO architechture.
I still don't get the picture why you need three WAPs per tower.
Can I make a suggestion? Get a reputable installer to install, say, two "towers" and observe their methodologies. Then you can follow.
