06-11-2012 05:01 AM - edited 07-03-2021 10:17 PM
I will be doing a site survey using the client's Cisco 1262 with only 1 radio (g/n), 3 antennas. What is the maximum transmit power, 20dBm or 23dBm?
I need to set the transmit power in the Airmagnet to 50% or 3dBm down as recommended by Cisco.
Solved! Go to Solution.
06-11-2012 05:29 AM
It depends on your regulatory.
Here is a link shows what is the maximum allowed power level (power level 1) depending on your AP regulatory:
Amjad
06-11-2012 05:29 AM
Amjad
06-11-2012 05:40 AM
The antenna has a 2,2dbi gain which means that the maximum Tx power will be 17dBm.
So, for my site survey, I will have to set the Tx power to 14dbm.
Lito
06-11-2012 05:53 AM
Have you checked the AP based on the regulatory?
doc have different ap regulatories (-A, -E, -Q ....etc). Be sure you match AP regulatory and radio type besides the gain. 2.4 and 5 GHz radios may have different max power level.
Please don't forget to mark answers and rate useful replies.
Cheers,
Amjad
06-11-2012 06:49 AM
The regulatory domain is -E.
Maximum Tx power with 2.2dBi antenna (2,4Ghz) is 17dBm
So, for my site survey, I will have to set the Tx power to 14dbm. Am I right.
