Cisco 1532i Ap Not Showing the SSID
amalmichaelvj
Dear team,
We have two Cisco oudoor1532i Ap in our Customer Site.Both devices are having only internal anteena.Both these Devices are changed to autonomous.i tried to Configure the SSID in These devices via Gui as well as Cisco network Assistant.After configuring the SSID it is not broadcasting the wireless network.What might be the reason.??
i am already familiar changing the Firmware of Cisco 700,1700,2700 series ap to autonomus Ap.But never faced the issue Before.
Any Document for Configuring 1532i ap with Single SSiD with Preshred Key.??
Sandeep Choudhary
paste the complete AP config here.
Dont forget to rate helpful posts
is there any gui guide for correct configuration??
I don't have access to console now..
Did you enable the Guest-mode in AP  to brodacst the SSID?
chekc this pic:
Check this posts as well:http://www.cisco.com/c/en/us/support/docs/interfaces-modules/security-modules-routers-switches/116586-config-ap-00.html
