Cisco 1552 Wireless Access Point Bandwidth
What are the respective bandwidths for the 1552 5Ghz and 2.4Ghz frequencies?
Pls refer below datasheet.
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1550-series/data_sheet_c78-641373.html
It can support PHY data rates upto 300Mbps (that is not application throughput you will get, it is much less than that ~ 40-60%. When you get multiple clients on AP, each individual clients shared that available bandwidth of the AP, so individual clients won't get much higher throughput)
Capabilities
●  2x3 multiple-input multiple-output (MIMO) with two spatial streams
●  Legacy beamforming
●  20- and 40-MHz channels
●  PHY data rates up to 300 Mbps
●  Packet aggregation: A-MPDU (Tx/Rx), A-MSDU (Tx/Rx)
●  802.11 dynamic frequency selection (DFS)
●  Cyclic shift diversity (CSD) support
Data Rates Supported
802.11a: 6, 9, 12, 18, 24, 36, 48, and 54 Mbps
802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54 Mbps
802.11n data rates (2.4 GHz and 5 GHz):
MCS Index[1]
GI[2] = 800 ns
GI = 400 ns
20-MHz Rate (Mbps)
40-MHz Rate (Mbps)
20-MHz Rate (Mbps)
40-MHz Rate (Mbps)
13.5
7.2
15
27
14.4
30
40.5
21.7
45
54
28.9
60
81
43.3
90
108
57.8
120
6
58.5
121.5
65
135
7
65
135
72.2
150
8
13
27
14.4
30
9
26
54
28.9
60
81
43.3
90
11
52
108
57.8
120
12
78
162
86.7
180
13
104
216
115.6
240
14
117
243
130
270
15
130
270
144.4
300
Rasika
*** Pls rate all useful responses ***
