We are doing a wireless CCTV system project using Cisco wireless network. Using Cisco 1552S as RAP and another Cisco 1552S as a repeater(just repeater-for meshing only). We got total 4 IP cameras and each camera is directly connected to Cisco 1532E using Ethernet Bridging.
Wireless Connection is as per below:
IP Camera 1 ---Wired--->MAP(1532E)------5Ghz------>RAP(1552S)
IP Camera 2----Wired--->MAP(1532E)------5Ghz------>MAP Repeater(1552S)------>RAP(1552S)
IP Camera 3----Wired--->MAP(1532E)------5Ghz------>MAP Repeater(1552S)------>RAP(1552S)
For the first IP Camera, the connection is OK and the system is working fine.
For IP Camera 2, 3 and 4 which is talking to MAP and then reaching RAP. These 3 cameras are always down during the night time(bandwidth high from camera during night time). Although the capacity of the wireless is theoretically good, but practically on site it is not stable.
The MAP will be hang in 2 days time which gives so much trouble for the 3 cameras.
If anyone can help me with some standard setting used for CCTV system using Cisco wireless network, it will be really a great help for me.
Thanks a lot.
Aravind. S
