Cisco 1700: Autonomous Mode?
I got gifted a used Cisco AIR-CAT1702I-A-K9  AP. It was previously used with a controller.
I would like to use it as an AP for my LAN, connected directly to my C2960.
As I understand it, I have to flash a different version of IOS for this. Can somebody point me in the right direction on how to do this?
Rasika Nayanajith
You need to have an autonomous image- k9w7 (eg ap3g2-k9w7-tar.153-3.JPJ3.tar) to use it as standalone AP. Without support contract, you may not able to download it  from Cisco.com (probably check with the person who gifted whether they able to support you).
Once you get software image, following post should illustrate the conversion process to go through.
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
https://mrncciew.com/2013/12/13/ap-conversion-using-mode-button
Rasika
*** Pls rate all useful responses ***
