11-19-2015 04:58 AM - edited 07-05-2021 04:16 AM
Hi, I'm new to the world of Cisco and routing and am trying to set up a 1841 as a 3G device. I have a working sim card but my cellular interface is flapping.. I think it has something to do with the cell profile but could use some help, thanks.
Below is the debug chat read out...
000621: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Attempting async line dialer script
000622: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
000623: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: process started
000624: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Asserting DTR
000625: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Chat script gsm started
000626: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Sending string: ATDT*99#
000627: *Nov 19 13:08:02.367 GMT: CHAT0/1/0: Expecting string: CONNECT
000628: *Nov 19 13:08:02.419 GMT: CHAT0/1/0: Completed match for expect: CONNECT
000629: *Nov 19 13:08:02.419 GMT: CHAT0/1/0: Chat script gsm finished, status = Success
000630: *Nov 19 13:08:04.423 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
000631: *Nov 19 13:08:04.439 GMT: %DIALER-6-BIND: Interface Ce0/1/0 bound to profile Di1
000632: *Nov 19 13:08:04.467 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up
000633: *Nov 19 13:08:11.143 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to down
000634: *Nov 19 13:08:13.139 GMT: %LINK-5-CHANGED: Interface Cellular0/1/0, changed state to reset
000635: *Nov 19 13:08:13.147 GMT: %DIALER-6-UNBIND: Interface Ce0/1/0 unbound from profile Di1
000636: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Attempting async line dialer script
000637: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Dialing using Modem script: gsm & System script: none
000638: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: process started
000639: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Asserting DTR
000640: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Chat script gsm started
000641: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Sending string: ATDT*99#
000642: *Nov 19 13:08:14.151 GMT: CHAT0/1/1: Expecting string: CONNECT
000643: *Nov 19 13:08:14.203 GMT: CHAT0/1/1: Completed match for expect: CONNECT
000644: *Nov 19 13:08:14.203 GMT: CHAT0/1/1: Chat script gsm finished, status = Success
000645: *Nov 19 13:08:16.203 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to up
000646: *Nov 19 13:08:16.227 GMT: %DIALER-6-BIND: Interface Ce0/1/1 bound to profile Di1
000647: *Nov 19 13:08:16.275 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to up
000648: *Nov 19 13:08:18.139 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to down
000649: *Nov 19 13:08:22.183 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to down
000650: *Nov 19 13:08:24.179 GMT: %LINK-5-CHANGED: Interface Cellular0/1/1, changed state to reset
000651: *Nov 19 13:08:24.203 GMT: %DIALER-6-UNBIND: Interface Ce0/1/1 unbound from profile Di1
3GKit48#n
000652: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Attempting async line dialer script
000653: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
000654: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: process started
000655: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Asserting DTR
000656: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Chat script gsm started
000657: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Sending string: ATDT*99#
000658: *Nov 19 13:08:28.203 GMT: CHAT0/1/0: Expecting string: CONNECT
000659: *Nov 19 13:08:28.251 GMT: CHAT0/1/0: Completed match for expect: CONNECT
000660: *Nov 19 13:08:28.251 GMT: CHAT0/1/0: Chat script gsm finished, status = Successo debu
000661: *Nov 19 13:08:29.179 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to downg c
000662: *Nov 19 13:08:30.255 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
000663: *Nov 19 13:08:30.271 GMT: %DIALER-6-BIND: Interface Ce0/1/0 bound to profile Di1hat
Chat scripts activity debugging is off
3GKit48#
000664: *Nov 19 13:08:30.315 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up
000665: *Nov 19 13:08:36.231 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to down
000666: *Nov 19 13:08:38.227 GMT: %LINK-5-CHANGED: Interface Cellular0/1/0, changed state to reset
000667: *Nov 19 13:08:38.235 GMT: %DIALER-6-UNBIND: Interface Ce0/1/0 unbound from profile Di1conf t
Enter configuration commands, one per line. End with CNTL/Z.
3GKit48(config)#int
000668: *Nov 19 13:08:41.291 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to up
000669: *Nov 19 13:08:41.315 GMT: %DIALER-6-BIND: Interface Ce0/1/1 bound to profile Di1cel
Chat script I'm suing
chat-script gsm "" "ATDT*99#" TIMEOUT 60 "CONNECT"
Dialer 1 conf
interface Dialer1
mtu 1400
ip address negotiated
ip access-group outside_access in
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxxxxxx
ppp chap password 7 xxxxxxxxx
ppp ipcp dns request
no cdp enable
service-policy output policy_pstn_nbar
end
cellular 0/1/0 profile
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = Internet
Authentication = PAP
Username: xxx, Password: xxxxxx
* - Default profile
Just done another debug with both cellulars up and here's the read out
000769: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Attempting async line dialer script
000770: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
000771: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: process started
000772: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Asserting DTR
000773: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Chat script gsm started
000774: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Sending string: ATDT*99#
000775: *Nov 19 13:20:49.527 GMT: CHAT0/1/0: Expecting string: CONNECT
000776: *Nov 19 13:20:49.575 GMT: CHAT0/1/0: Completed match for expect: CONNECT
000777: *Nov 19 13:20:49.575 GMT: CHAT0/1/0: Chat script gsm finished, status = Success
000778: *Nov 19 13:20:51.575 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
000779: *Nov 19 13:20:51.591 GMT: %DIALER-6-BIND: Interface Ce0/1/0 bound to profile Di1
000780: *Nov 19 13:20:51.635 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up
000781: *Nov 19 13:20:53.327 GMT: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/1 is DOWN
000782: *Nov 19 13:21:04.039 GMT: %LINK-5-CHANGED: Interface Cellular0/1/0, changed state to reset
000783: *Nov 19 13:21:04.047 GMT: %DIALER-6-UNBIND: Interface Ce0/1/0 unbound from profile Di1
000784: *Nov 19 13:21:04.051 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to down
000785: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Attempting async line dialer script
000786: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Dialing using Modem script: gsm & System script: none
000787: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: process started
000788: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Asserting DTR
000789: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Chat script gsm started
000790: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Sending string: ATDT*99#
000791: *Nov 19 13:21:05.051 GMT: CHAT0/1/1: Expecting string: CONNECT
000792: *Nov 19 13:21:05.107 GMT: CHAT0/1/1: Completed match for expect: CONNECT
000793: *Nov 19 13:21:05.107 GMT: CHAT0/1/1: Chat script gsm finished, status = Success
000794: *Nov 19 13:21:07.107 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to up
000795: *Nov 19 13:21:07.131 GMT: %DIALER-6-BIND: Interface Ce0/1/1 bound to profile Di1
000796: *Nov 19 13:21:07.179 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to up
000797: *Nov 19 13:21:09.039 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to down
000798: *Nov 19 13:21:14.119 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to down
000799: *Nov 19 13:21:16.115 GMT: %LINK-5-CHANGED: Interface Cellular0/1/1, changed state to reset
000800: *Nov 19 13:21:16.139 GMT: %DIALER-6-UNBIND: Interface Ce0/1/1 unbound from profile Di1
000801: *Nov 19 13:21:17.295 GMT: %CELLWAN-2-MODEM_UP: Modem in HWIC slot 0/1 is now UP
000802: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Attempting async line dialer script
000803: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
000804: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: process started
000805: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Asserting DTR
000806: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Chat script gsm started
000807: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Sending string: ATDT*99#
000808: *Nov 19 13:21:19.299 GMT: CHAT0/1/0: Expecting string: CONNECT
000809: *Nov 19 13:21:19.391 GMT: CHAT0/1/0: Completed match for expect: CONNECT
000810: *Nov 19 13:21:19.391 GMT: CHAT0/1/0: Chat script gsm finished, status = Success
000811: *Nov 19 13:21:20.239 GMT: %PKI-3-POLLCACERT: Polling CA certificate .....
000812: *Nov 19 13:21:20.271 GMT: %PKI-3-POLLROUTERCERT: Polling Router certificate .....
000813: *Nov 19 13:21:21.115 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to down
000814: *Nov 19 13:21:21.391 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up
000815: *Nov 19 13:21:21.407 GMT: %DIALER-6-BIND: Interface Ce0/1/0 bound to profile Di1
000816: *Nov 19 13:21:21.459 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up
000817: *Nov 19 13:21:27.455 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to down
000818: *Nov 19 13:21:29.503 GMT: %LINK-5-CHANGED: Interface Cellular0/1/0, changed state to reset
000819: *Nov 19 13:21:29.511 GMT: %DIALER-6-UNBIND: Interface Ce0/1/0 unbound from profile Di1
000820: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Attempting async line dialer script
000821: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Dialing using Modem script: gsm & System script: none
000822: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: process started
000823: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Asserting DTR
000824: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Chat script gsm started
000825: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Sending string: ATDT*99#
000826: *Nov 19 13:21:31.515 GMT: CHAT0/1/1: Expecting string: CONNECT
000827: *Nov 19 13:21:31.567 GMT: CHAT0/1/1: Completed match for expect: CONNECT
000828: *Nov 19 13:21:31.567 GMT: CHAT0/1/1: Chat script gsm finished, status = Success
000829: *Nov 19 13:21:33.567 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/1, changed state to up
000830: *Nov 19 13:21:33.591 GMT: %DIALER-6-BIND: Interface Ce0/1/1 bound to profile Di1
000831: *Nov 19 13:21:33.647 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to up
000832: *Nov 19 13:21:34.451 GMT: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to down
000833: *Nov 19 13:21:39.527 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/1, changed state to down
000834: *Nov 19 13:21:41.523 GMT: %LINK-5-CHANGED: Interface Cellular0/1/1, changed state to reset
000835: *Nov 19 13:21:41.547 GMT: %DIALER-6-UNBIND: Interface Ce0/1/1 unbound from profile Di1
000836: *Nov 19 13:21:44.547 GMT: CHAT0/1/0: Attempting async line dialer script
000837: *Nov 19 13:21:44.547 GMT: CHAT0/1/0: Dialing using Modem script: gsm & System script: none
000838: *Nov 19 13:21:44.547 GMT: CHAT0/1/0: process started
000839: *Nov 19 13:21:44.547 GMT: CHAT0/1/0: Asserting DTR
Is it an issue of low signal or maybe WIC hardware?
11-19-2015 05:18 AM
#show cellular 0/1/0 radio
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10712
Current RSSI = -92 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x1F2
RSCP = -97 dBm, ECIO = -9 dBm
11-23-2015 04:06 AM
anyone?
