Cisco 1941W - Wireless - 2 VLANs
aravindhs
Hello Experts
I'm writing to get some urgent help with Wireless on Cisco 1941W.
The requirement is to have two subnets/VLANs/BVIs on the router (one for corporate access and another for Guest-Internet access. Both are to have wired and wireless clients.
On the router,
BVI1/VLAN1 is Corporate Access - 10.20.31.254/25
BVI10/VLAN 10 is Guest Internet - 10.20.31.126/25
With G0.1 as a native dot1q vlan on the AP and 31.253/25 as bvi1, the AP pings .254 pings fine.
With G0.10 as a dot1q vlan 10 on the AP and 31.253/25 as bvi1, the AP pings .125 won't ping.
I'm unable to get it to work. Can you please help ?
Many thanks
Aravind
Stephen Rodriguez
Can you post the entire config?  Router and AP
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hello Sir,
Thank you for your reply. I read another thread about the 1941W wireless config and I think i may have sorted it out. The customer is yet to test it and get back to me but I think it should be pretty much ok. The platform specific thing that I did not know was the switchport mode trunk on the wlan-gig0/0 interface on the router. Apart from that the config seems to be straightforward. I will come back to you if it doesn't work.
aravind
