Cisco 2100 wireless controller question
stillanoobin2020
Community Member
I recently got a new Cisco 2100 series wireless controller.
I need to set it up in a multi vlan environment.
Having it connecting and registering WAP that are connected to my switches is not a big issue.
What i'm having trouble figuring out is how to set it up so that i can make use of its 2 POE ports.
What i'm trying to figure out is what VLAN those ports will be in when i connect the WAP to it.
I can set VLAN tags to ports but only if i create new interfaces, and i dont think i would have to create a new interface for each WAP i need to connect.
I hope i'm making myself clear on this if not please ask and i will try to clarify.
Ven Taylor
Level 8
Level 8
Don't confuse "SSID's" "interfaces" and "ports" on your wireless controller.
They're very different, but depend on one another.
First, configure your ports (up/down, duplex, etc) at Controller / Ports
Then configure an interface on the controller and then assign that interface to a physical port at Controller Interfaces
Interface configuration is where you configure vlan ID, IP address, mask, gateway, etc.
SSID creation - Go to WLANs and add or change an ssid.  Point it to an interface.
The interface/port marriage takes care of the rest.
Ven
Ven Taylor
Ok so i was not clear enough.
lets say that in my environment i have 2 vlans 10 and 100
On my switch port i can configure it a a trunk and allow vlans 10 and 100
on the wireless controller i create 2 interfaces 10 and 100
interface 10 is connected to port 1, with ip address 10.10.10.10 255.255.255.0 and assigned to vlan 10, i can then configure an SSID to that interface
interface 100 is connected to port 1, with ip address 10.100.100.100 255.255.255.0 and assigned to vlan 100, i can then configure an SSID to that interface
This puts port 1 on the controller in trunk mode and allows communications with the rest of the network.
On a switch i can configure the WAP ports to either vlan so they get an ip address from dhcp and bind to the controller.
However i want to use POE for 2 of my access point, and unforutnatley i dont have POE switches.
SO i want to meke use of the 2 POE ports on the wireless controller, so i plug a WAP in port 7.
Which VLAN is the device in?
