Cisco 2500 Series Wireless Controller - Certificate issue
m.chandra2010
Hi there
can anyone help me understanding the Certificate concept on a Cisco wireless controller specifically with difference between Local significant certificate (LSC) and Web Auth Certificates.
the client PCs (except mobile devices) are having trouble getting authenticated on wifi connections and this has started after certificate being renewed on the server.
any quick help would be appreciated.
Scott Fella
Need to know what SSID your having issues with and what type of encryption. Can you post the show WLAN <WLAN ID>
Also what certificate did you upload if any?  Any more detail would help.
-Scott
-Scott
abwahid
Level 4
Level 4
Refer to below case.
http://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/118838-configure-wlc-00.html.
Hopefully it would be helpful.
m.chandra2010
Thanks for your response guys.
the issue is sorted. it was actually NPS on windows 2008 server which was not publishing new certificate.
all sorted. Thanks
