cisco 2504 connectivity problem
utkangunay
Community Member
i have a cisco 2504.
i set up  vlan security password. but one  day later  i don't connect to ap's.
again log in the cisco web interface and set up same password for vlan than i connect sucsesfuly.  and one or two day later same problem.
i don't connect to ap's again .   than repeat the same procedure.  log in the cisco web interface and set up same password for vlan than i connect.
anyone have a solution
Sandeep Choudhary
do you mean... WLAN connection issue ?
How did you setup WLAN on WLC ?
Dont forget to rate helpful posts
i am using 2 years this wlan configuration. I have been having this problem for the last 6 months.  i don't change anytihing.
are facing the wlan issue with all device (Iphone /android/windows) or only with few?
can you paste the sh wlan <id> output from WLC.
Also paste the error which you are getting!!
