cisco 2504 wireless controller forget username and password
arthurbustillo
hi,
i just want to ask how i can do password recovery with my wireless controller without erasing the configuration
Scott Fella
When you first configure the controller and reboot, you will see an option to recover the password.  This is a one time option and if the controller has been up and rebooted a few times, then the only other way to change or add another user so you can login is with Prime Infrastructure and the use of snmp. You can download that and install that in ESXi 5.5 and get an eval license.  Or you can dig around and search for an smnp mib that will change it.  That piece I don't know about:)
-Scott
-Scott
scott, which version would you download for this?
