Cisco 2504 WLC two sites with T1 between each site
slwdaw_2
I have a customer with 2 sites, connected by T-1.
The need wireless on each site, will the Cisco 2504 be able to run both sites or do they need to get two WLC controllers.
Site A    Cisco WLC --> Cisco Switch -->  Cisco Router   --> T1 <-- Cisco Router -- Cisco Switch
             vlan1- internal-wlan        vlan 1 - internal Network  *??? Should I create a Vlan 40 ??
             vlan10 - managment
             vlan 50 - guest-wlan
How to create the interface on the WLC 2504  of the VLan of the remote side?
It doesn't allow me to use vlan 1, since it is already used on internal-wlan
If I created a vlan40, will it work?, since the WLC doesn't really know about the vlan40 on the other side of the T-1
Stephen Rodriguez
you could go with just one WLC, but unless you are passing layer 2 across the T1 you won't Ned to have the remote VLAN configured in the WLC. Instead what you would want to do is HREAP at the remote site.
HREAP will keep the traffic local to the remote site, and follow the local routing policy if it needs to traverse the link. It will also allow the remote site wireless to,stay up if the T1 goes down.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080736123.shtml
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Leo Laohoo
How many WAPs are you planning to have in total?
