Cisco 2602 could not join the Wireless controller.
karinn001
I have 2602 AP and i rebooted after rebooting i could not joining the controller (2502) and getting the following logs. Kindly suggests me any solution. Moreover after rebooting AP showed the admin "status disable" and clean air status is "down". I manually enable both these options after that Cisco  Prime and controller showing no error but both the radio channel could not on or no signal is broadcast.
*Mar  1 00:00:11.615: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:11.619: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:15.123: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:18.795: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:25.171: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:27.827: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 04:30 by prod_rel_team
*Mar  1 00:00:27.827: %SNMP-5-COLDSTART: SNMP agent on host APf8c2.8838.9850 is undergoing a cold start
*Mar  1 00:00:27.883: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:27.883: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:28.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:28.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:28.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:28.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:31.295: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:31.295: DPAA Initialization Complete
*Mar  1 00:00:31.295: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:32.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:36.891: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:00:36.891: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:37.043: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:56.635: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:59.135: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:01:00.227: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.319: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:02.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:02:56.639: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
*Mar  1 00:03:04.663: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:04.671: %IP-4-DUPADDR: Duplicate address 10.0.10.63 on BVI1, sourced by 4c4e.353d.85b0
*Mar  1 00:03:04.715: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.0.10.63, mask 255.255.255.0, hostname APf8c2.8838.9850
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:03:06.643: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:15.643: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:03:25.643: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 31 12:26:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.10.52 peer_port: 5246
*Aug 31 12:26:40.479: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.10.52 peer_port: 5246
*Aug 31 12:26:40.479: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.10.52
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.0.10.52
*Aug 31 12:26:40.923: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Aug 31 12:26:40.995: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Aug 31 12:26:41.059: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller PK-KARAC-WLC1
*Aug 31 12:26:41.343: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Aug 31 12:26:41.923: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Aug 31 12:26:41.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
15 Replies 15
Check this document :
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1522-lightweight-outdoor-mesh-access-point/113678-wlan-mesh-config-ex.html
Dont forget to rate helpful posts
