Cisco 3702i Issues
Neville Price
Level 3
Level 3
I have been installing and configuring, a large deployment of new 3702i access points.  I have an issue on a couple of them, they have joined the controller, and downloaded the correct version, and are now blinking green constantly, I can see them on the switch and WLC,  99% of all the others are working correctly.
5 Replies 5
Leo Laohoo
Could mean the AP didn't re-join the controller after firmware upgrade.
Console into the AP and post the following output:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
The AP Has rejoined the controller, with the correct version etc, but is still constantly blinking green.
See the meaning of LED status Indication :
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/3700/quick/guide/ap3700getstart.html#60734
Also check:
Is AP getting IP address ?
Is there any cable related issue connecting to switch ?
provide the console logs to see where and what actually happening?
Don't forget to rate helpful posts
All sorted, very strange issue, it was getting an IP and connecting to the WLC, a simple manual reboot at the AP side did the trick.
Then maybe someone's playing a prank and enabled LED flashing to be continuous.
