08-15-2023 11:51 PM
Good day
I have a 5508 wireless controller and AIR-AP3802E-E-K9 APS.
to which firmware version can I upgrade controller firmware so that also APs gets updated and everything works perfectly after?
and what is the simplest way to go about doing an upgrade?
controller currently
| Software Version | 8.5.161.0 |
| Field Recovery Image Version |
AP'S currently primary SW ver 8.5.161.0 backup SW ver 8.5.140.0
Your positive feedback will be highly appreciated.
Thank you.
08-16-2023 01:50 AM - edited 08-16-2023 01:50 AM
The "highest" firmware the 5508 can go is 8.5.182.0. And this version can support the 3800.
Do not forget to read the Release Notes.
08-16-2023 02:03 AM
As per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html , use :
https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
The use of the 8.5.182.0 , release is discouraged because of a few bugs
Upgrade procedure documentation : https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
M.
08-16-2023 08:57 AM
Current latest version is 8.5.182.11 - see link below.
