Cisco 5508 interface design problem
now i have connect wlc into infra same picture but ap can't register into wlc. How create interface for this diagram. please help me because access switch is unmanage switch i can't config trunk on this.i can install for this solution this isn't ?
thank you for best support.
samy
devils_advocate
Level 11
Level 11
Why are your AP's on different Vlans?
If you plan to create SSID's on different Vlans then you will need a trunk port to the WLC as the switch needs to pass tagged frames to it and the WLC needs to pass tagged frames back.
Out of interest, you are using a 5508 which is a fairly expensive piece of kit yet you are connecting it to an unmanaged switch. Why?
