Cisco 871W wireless drops
timbaca888
I have a Cisco 871W that periodically will drop its signal. Any tips on how to configure this for maximum reliability? I set it to use chanel 2462.
Leo Laohoo
Sure, take this line away.
The problem could be the fact that you've specified to the WAP what channel to use.  Now if you have a neighbor wifi using this same channel ...
Another thing:  The 870W has two antennas.  How many have you installed?
