Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless advice
ievalleyccie
Level 3
Level 3
Hi ,
I am new in the Cisco Wireless . I've 3 APs and I'd like to configure them as Hub and 2 Spokes  .
What I know that I should configure the Hub as root and the Spokes as Non-Root bridge
and I don't know If i should connect all the APs to switches or what ?
Pls Advise
5 Replies 5
Thanks but should i connect the Hub only to a switch or it doesn't matter ?
A wireless bridge is use to connect to physical device or location using wireless.  Like this:
LAN A --- WAP A << ---- WIRELESS ---- >> WAP R -- LAN R
what about the following
                                           ---------------Wireless ------------------- WAP B  ----- Wirless clients 1 (No switch)
Lan A(Switch) --WAP A      |
                                            --------------Wireless ------------------- WAP C  ----- Wirless clients 2 (No switch)
Can Wireless client 1 connect to Wirless Clinet 2 ?
Sure.  Why not.
