Cisco 892 Wireless issue
aakashojha
Hi team,
I have a strange error in Cisco CISCO892W-AGN-E-K9 that i bought for our clients a month back.
- the router doesn't display the SSID for a longer period. Its like on and off of the SSID, showing sometimes and sometimes blank.
Please help with the issue.
7 Replies 7
Scott Fella
Can you post the AP config. Is it different devices having issues or just one. They have within coverage.
-Scott
Hey Scott,
Please not the config below-
dot11 syslog
dot11 ssid NWEDC
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 1102161612020003162F2A
username nwedc privilege 15 secret 5 $1$.SrJ$u3EVvjrMbli/I6UODVJoW.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid NWEDC
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
Scott Fella
You need to either use WPA/TKIP or WPA2/AES. You have WPA2/TKIP and that is why. Try to change that and it should fix your issue.
-Scott
Thanks, i will try and let you know. But i do not understand what it has to do with the SSID
Hi Scott,
It does not work. I still have the same issue. SSID is ON and Off.
Hi, What is the code version the AP module is running?
Can you confirm the radio interface status when the issue is reported.
Do you see any r0.core/r1.core files in "sh flash"?
Sahil
