Cisco 9013AXI Single AP Best Practices
timgrantham
Hi all,
I'm looking for a bit of advice - I have a single Cisco 9130AXI access point at home which I have set-up according the the best practices analyser.
The question I have, being a single access point in the whole environment, is there anything I shouldn't have enabled, or should have enabled?
Thanks for your help!
-Tim
16 Replies 16
Thanks Scott, that's very helpful and very much appreciated.
What settings are recommended for FRA?
I don't use the FRA radio to be honest.  It doesn't mean you can't and play around with the settings.
-Scott
