cisco 9800 wireless migration
naresh86
Visitor
we are planning to migrate 5508 (8.10) wlc to 9800 as a part of DNA structure. physical appliances delivery were delayed. So virtual wlc is deployed. basic configuration was done
My question here is, can we use IRCM or mobility group to migrate all the data from 5508 to 9800(no configuration on it except mgmt ip address and Webgui access) without any additional configuration. Please let me know if its possible and also important notes to follow(if there is).
Rasika Nayanajith
 "Can we use IRCM or mobility group to migrate all the data from 5508 to 9800? "
There is no way you to migrate configuration data from 5508 to 9800. You can use the below config converting tool to get equivalent CLI configs for your 9800. However, you should go supported configuration & apply it once you understand what those configurations will do.
https://cway.cisco.com/wlc-config-converter/
In general, you should not have client SVI on your 9800 (in AireOS you always need client SVI on 5508 - called dynamic interfaces). Also understand tags & profile concept in 9800, those are new concepts & no equivalent in 5508. Below post may help you to get high level overview
https://mrncciew.com/2022/06/30/9800-tags/
Once you get 9800 configured & AP registered, you should able to use config analyzer tool given above by Marcel to validate your 9800 configuration agains Cisco best practices
Rasika
*** Pls rate all useful responses ***
Mark Elsen
                             - You can do IRCM between 5508 and 9800 (virtual wlc) : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html , Check Table 1 and look at column Cisco AireOS-IRCM Interoperability  , for the  9800 virtual wlc  you can always have a sanity check on its configuration with  the CLI command : show  tech wireless , have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
Rasika
