CISCO ADSL + VPN solution
joand3512004
Guys,
I have a client that receives the Net Virtua ADSL Link, with the following scenario:
Link >> Modem >> TPLink >> Switch >> 5 Access Points. However, I need a CISCO solution for after the Modem, I insert an equipment to establish a Tunnel with the VPN of my company, and can monitor the lan network of the client (switch) any ideas?
The APs will be managed by the CISCO WLC8500, and with Cisco Prime, I even need access to the switches to make it easier to troubleshoot.
Seb Rupik
Hi there,
For a small branch site like this you will want an ISR router. You say it will connect after the modem, but your question says it must support ADSL. If you don't need ADSL connectivity go for a C881. If you require an ADSL connection you can remove the PE modem and go for a C887VA or C887VAM.
Try the Cisco tool yourself:
https://www.cisco.com/c/dam/assets/prod/routers/cisco-router-selector/index.html#/branch
cheers,
Seb.
