10-19-2021 02:39 AM - edited 10-19-2021 05:02 AM
hello all
I have issue with wireless access for devices connected to through WIFI the problem is the device connect and disconnect
I change the device but same vendor and change the access point all make same result i use debug to see where is the problem and this what i found
disc_client_reset_ctrlr_slotunit: MAC xxxx.xxxx.xxxx newclient 0x5772C88 OLD slot 255
Oct 18 09:53:57.173: 2E00BC19-0 832D96 -
disc_client_radiohop_handle: MAC 0000.0000.0000 oldclient addr 0x0 NEW slotunit 0 newclient addr 0x5772C88 NEW slotunit 0
Oct 18 09:53:57.173: 2E00BC27-0 832D96 - uapsd_compliant_client 0
Oct 18 09:53:57.173: 2E00BD16-0 832D96 - KeySet1 session key type 604 aid 2 len 16, idx: 1, 38F1367AC35AD2A8
Oct 18 09:53:57.213: 2E0164F2-0 832D96 - fc C0 mode 33B0 st 40004/1A
Oct 18 09:53:57.213: 2E01654B-0 832D96 - stop: request aid 2
Oct 18 09:54:16.832: 2F2CBA15-0 832D96 - delete timeout
Oct 18 09:54:16.832: 2F2CBBF6-0 832D96 - freed
Oct 18 09:54:16.832: 2F2CBC36-0 832D96 - delete session key, AID 2
Oct 18 09:54:16.832: 2F2CBD65-0 832D96 - Not a Flex connnected,not holding AID 2
it says that the device not holding the AID (Association Id)
I found this bug CSCve81314 on cisco WLC
The issue does not affect Cisco IOS APs that run in autonomous mode.
my AP is a stand-alone AP (autonomous AP)
flash:/ap3g2-k9w7-mx.153-3.JA12/ap3g2-k9w7-xx.153-3.JA12
I need your experience on this issue and thank you...
10-19-2021 06:12 AM
- Try the latest autonomous-software-version for the particular ap-model.
M.
10-19-2021 06:23 AM
same AP with the same ver working without problem in a different branch
10-19-2021 06:45 AM
- Bug conditions can have complex-causes due to specific circumstances , such as client model. channel use , other clients, capacities, resources and much more , therefore the advice is still applicable.
M.
10-19-2021 08:26 AM
Well you kind of isolated the issue... have you tried to swap out that ap for another? Also, you should try to test with a different SSID just to see what the results are.
