Cisco AIR-AP1142
mcaoile
Just out of the box. Configured IP address, security and enabled the radios. When I checked the gigabit interface it shows:
      Software status -- Enabled
      Hardware status -- Down
Is this an indication that the AP has a hardware problem and I can send it for RMA?
Thanks Mcaoile for the update and we are glad that the issue is fixed. Please do mark this query as "Answered".
thanks
Vinay
Thanks & Regards
Leo Laohoo
Can you post the entire output where you saw this result?
Vinay Sharma
Level 7
Level 7
Hi mcaoile,
As Leo suggested, could you please paste the full output?
thanks,
Vinay
Thanks & Regards
Hi Leo/Vinay,
I found the problem.  It was a patch cable problem.
Thanks for your replies.
mcaoile
thanks
Vinay
Thanks & Regards
