cisco air-ap1231g with air-ant3351
koorosh_l
i have heard that i can use air-ant3351 antenna with air-ap1231g.. i wanna know is that ok???is it a must to use antenna with that access point to have good coverage?i appreciate your opinons.
srdja
Yes, you can use any Cisco 2,4GHz antenna (both for b or g radios), and yes you will have better coverage with antenna (without antenna you will have coverage of 3-4 feet (!!) only).
Good luck,
Srdja
