Cisco Air-Ap2802I-E-K9 cannot convert to Mobility Express
m.yildiz
Dear Community Members,
I have Air-Ap2802-e-k9, somehow i cannot convert it to mobility express.
i have downloaded over tftp the tar image, it downloads, but it does not converts,
it reboots, with the normal image 8.3.143.0
it is still looking for an controller.
Anyone can help me in this issue?
22 Replies 22
hi did anyone fixe the above issue? i have 4800 CAPWAP and trying to upgrade to 8.10-185 latest mobility express and it gives the same error. the file correpted. i tried multiple firmware versions. 121, 185 and so on. can anyone help me. sometime it was throuwing error no space. then i erased the capwap config full and tired that error gone but still the corrupt error keeps coming. its annoying.
RMA the AP.
rjara0001
Hi all, I have the same issue.
I downloaded the last ME version.
Upgraded CAPWAP version to a newer than 8.3 (as indicated in literature).
Used MD5 Hash to verify images and it is OK for both.
TFTP load passed 100% and when the process begins the process to change to ME it fails. (corrupted image, no space or something)
You have to go
from 8.3 to 8.5 and then up.
you cannot upload from 8.3 to 8.10
step by step
will solve the issue
vangogh_21
Does anyone have 8.3 or rather AIR-AP2800-K9-ME-8-3-150-0.tar
This is the only one that is below 50mb which fits the flash. My contract wont allow me to download the older ones.
manaszk-cisco
Same here I have:
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1028584/663900K bytes of memory.
Processor board ID FDW2243D25E
AP Running Image : 8.5.135.0
Primary Boot Image : 8.5.135.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.24
Base ethernet MAC Address : 70:xxxxxx
Part Number : 73-xxxxx
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FDOxxxxx
Top Assembly Part Number : 068-xxxxx
Top Assembly Serial Number : FDWxxxxx
Top Revision Number : D0
Product/Model Number : AIR-AP2802I-E-K9
Now, with command:
PWA-xxxxxx#ap-type mobility-express tftp://10.xxxxx/AIR-AP2800-K9-ME-8-10-151-0.tar
Starting the ME image download...
It may take a few minutes to finish download.
If it is longer, please abort command, check network connection and try again
######################################################################## 100.0%
Image transfer complete.
Image downloaded, writing to flash...
do CHECK_ME, part2 is active part
Image signing verify success.
upgrade.sh: part to upgrade is part1
upgrade.sh: Image version 8.10.151.0 seems corrupted. Retry exhausted. Stop writing.
and so on, about corrupt file.
File image was downloaded from Cisco page. No idea where from to get not corrupted img.
I have one clue:   image transfer (via tftp) was always successfull, until once I commanded "reload" from CLI after a succesful writing. Since that time, any next attempt to flash is "corrupt". Maybe that's the reason?
DivakaranV
hi all - this is a known issue in ME and you try upgrading the existing code if you are running capwap to 15.3.3jpj3 or something like that and then to 8.10.185 me. it should work and try and tell me. thanks
i am successful after so many attempts and bricking one of the 4800
DivakaranV
Hi All - to upgrade to ME, you must upgrade your existing code to righ CAPWAP versoin and then try. it should work. thanks
