cisco air-cap 1702i-a-k9
clogangma
This came with zero instructions? how to i connect to it by it's ip address? What is the default ip address?
whats the default username and passowrd?
Stephen Rodriguez
The AP you listed is a CAPWAP enabled and should be used with a Cisco WLC.
If you need it to be a standalone AP, then you need to Convert it to run the aIOS image.
After that, it depends on what you are looking to configure, but here is the Configuration guide
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
There are a lot of guide out there. Here is one:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1700/quick/guide/ap1700getstart.html
Also, the model you have requires a wireless lab controller because it has "CAP" in the model.
Default AP username and password is Cisco/Cisco
-Scott
-Scott
