Cisco Air-CAP1602I-A-K9 first configuration help
rameshkrishnan
Need help in configuring Cisco Aironet Air-CAP1602I-A-K9 , i have got the IP address of the interface, it cannot access from the web browser.
not even , i cant enter to the global configuration mode in CLI. use all commants like "Configure", "Configure terminal"
Leo Laohoo
The product ID prefix of "CAP" stands for "controller-based AP".  If you need to use this AP like an autonomous AP then you'll need to convert the AP from running controller-based IOS to autonomous IOS.
22 Replies 22
Leo Laohoo
Saurav Lodh
Level 7
Level 7
Follow the controller based ( lightweight ) Ap to Autonomous AP conversion from
https://learningnetwork.cisco.com/thread/14405
Moin Ilyas
Level 4
Level 4
Once converted to Autonomous Image, please refer to the following links:
www.cisco.com/c/en/us/td/docs/wireless/access_point/1600/quick/guide/ap1600getstart.html
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3.html
Hope that helps.
rameshkrishnan
I tried to convert the same using mode button, Tftp is not taking the image. not working any archive commands. please help to resolve
Hi Ramesh,
You AP has which image(Lightweight or standalone) ?
paste the output of this: sh version
Don't forget to rate helpful posts
Hi Sandeep, thanks for your responce.
please find the following show version
AP24e9.b34b.e72d#show version
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(4)JA1, RELEAS
E SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:41 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT
WARE (fc1)
AP24e9.b34b.e72d uptime is 9 minutes
System image file is "flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-A-K9 (PowerPC) processor (revision B0) with 98294K/32768K byt
es of memory.
Processor board ID FGL1752S3TE
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.5.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 24:E9:B3:4B:E7:2D
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17466QYL
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1752S3TE
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-A-K9
Configuration register is 0xF
Hi Ramesh,
Did you tried this method:
archive download-sw /force-reload /overwrite tftp://10.0.0.1/ c1240-k9w7-mx.124-25d.JA2.tar
https://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
Try this instead of Mode button.
Alresdy Tried the same command is not working
Hi Ramesh,
1. Did you put the computer and AP in same subnet ?
2. Can you ping the AP IP from your laptop ?
what is the output of:  sh ip int brief
Show ip int brief commant is not working but the BVI 1 interface assigned an ip as 10.0.0.3
earlier it was pinging to my pc IP 10.0.0.4
Now its not. showing error no protocol is running
AP24e9.b34b.e72d#show ip interface bv
AP24e9.b34b.e72d#show ip interface bvI1
BVI1 is up, line protocol is up
  Internet address will be negotiated using DHCP
  Broadcast address is 255.255.255.255
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is disabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
 --More--
Not in Bound state.
*Mar  1 01:03:41.113: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP
. Renewin  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: MCI Check
AS per this output there is no IP address assigned.
1. Please assign IP address manually to APs Ethernet interface(10.0.0.3/24)
2. Your Laptop must have ip as 10.0.0.5/24
3. Connect laptop and AP via Ethernet cable.
4. If you can ping then run the archive command "
archive download-sw /force-reload /overwrite tftp://10.0.0.5/ c1240-k9w7-mx.124-25d.JA2.tar
Every thing got done, same has been deployed in my network.
Thanks For your valuable support Sandeep Choudhary and all other advisers.
Hi all.
Only new to this. So I have a Air-Cap1602I-N-K9, version info is Software AP1G2 RCVK9W8-M, Version 15.2(2)JB, which I understand is a lightweight, So my question is which Autonomous AP IOS Software/version should I use, and the process to download it.
Cheers
Robert
