CISCO air-cap1702i-d-k9 CONFIGURATION
I am trying to configure air-cap1702i-d-k9  in autonomous mode. I have connected the AP via console and established communication but i am unable to connect the AP using web. I have assigned capwap ip and default gate way via cli. can any one help me to fix this?
6 Replies 6
Philip D'Ath
You you executed the command "capwap ap autonomous" ?
no i didnt. But do i need to execute this cmd for accessing the AP from browser?
You have to run that command to put the access point into autonomous mode.
thanks for you reply. I understand what you are suggesting.
Could you pls tell me if there is any procedure to follow to access the AP from web browser?
Thanks for this command, i am trying from hours to make AP standalone.
mohanak
