Cisco Air-cap2602i-e-k9 firware issue
demon123456
Team,
My  query regarding my device Cisco Air-cap2602i-e-k9 which i want to convert into lightweight to autonomous 2602i is this possible to do that,if yes then i need the exact guide to convert the same device as i am not able to do configuration on the leight weight it doesnot support some features
6 Replies 6
What is the cisco aironet 2601i factory default version
I don't understand this question.
can you tell me which version of ios on cisco aironet 2601i is come from cisco factory ,when i execute the command it shows me LWAPp IMAGE 7.1.0.5 ,is it the default version is lwapp or the autonomous version ,and i am not able to do the LWAPP to Autonomous Conversion by the method given by you may be this device not support that feature or something wrong on the method its shows me on 1102 aironet device method not the same as i said so please check and resolve my issue,
*Sigh*
Autonomous IOS for the AP 2600 can be found HERE.
It doesn't matter what the IOS was shipped out of the AP because anyone can change the IOS to suit their needs.  Follow the instruction and use a little bit of common sense.  A lot of people have used the instructions to convert an AP (from controller-based IOS) to autonomous without any hitch.
