Cisco AIR-LAP1042N-N-K9 connecting to Cisco 2504 WLC drop outs
jake.alamdar.1
I work in Australia and am currently haveing the following issue with my companies WLC and APs.
AP: AIR-LAP1042N-N-K9 (country code Australia)
WLC: 2504 (contry code Australia)
The light weight APs connect and join to the Cisco WLC and show this on the web GUI, but they randomly just dissconnect as say "not joined" then they will join again. Sometimes it will be stable for a while othere times it will happen quite frequently. I have attached some of the summarie errors from a few of the APs.
We have APs located in different parts of the world all connecting back to the same controller in our head office.
The error below is one that I see quite often, but cannot seem to find much information on the cause.
"number of message retransmission to the ap has reached maximum site"
If you need any mor einformation please do not hesitate to ask.
Any help would be greatly appreciated.
Kind Regards,
-Jake
30 Replies 30
Leo Laohoo
This could be your reason.  The APs heartbeat probably couldn't see the WLC, possibly due to congestion, and the WLC has marked them as "dead".
Go to the Monitor > Access Point Summary > All APs > Detail > click on the AP.
Under the Generals tab, under Time Statistics, what figures do you have there?
Helo Leo,
Thank you for such a quick responce. Is there any setting I can update on my WLC to stop it form marking the APs as "Dead"?
Please find attached the TIme Statisitcs for all of the APs. I have named them according to their country location.
Kind Regards,
-Jake
America APs
Australia APs
The above AP was resently reset by me.
Ireland
UK
You may need to consider FlexConnect.
Who's your WAN provider?  Telstra, Optus?
Telstra is the WAN provider, hmmm we already have FlexConnect enabled. What does FlexConnect do exactly?
Also i was looking at the Wireless LAN Complinace Status and it says the 'N' is the country code for Australia? Is this correct? I have seen a few, A, N, Z? What hapens when the Country code of the Controller and AP dont match up? Or from the image at the bottom (I am using 802.11b/g/n) the APs will need to be AIR-LAP1042N-A-K9?
AP: AIR-LAP1042N-N-K9 (All APs the same)
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 15.0
Build Type....................................... DATA + WPS
Configured Country............................... AU  - Australia
Maximum number of APs supported.................. 25
In regards to regulatory domain, that's a separate issue.  Your APs deployed in US, for example, should be using "-A" but that will complicate what channels you can use.  But this is not what is happening.
I believe that your APs are loosing heartbeat to your WLC.  FlexConnect is good because the AP can remain operational even if it's lost the heartbeat to your controller.  The main proviso with FlexConnect is there's got to be a local authentication to authenticate new users.
Your geographical location sounds like you're from DFAT.
Hi Leo,
So when you say:
Do you mean local authenitcation such a RADIUS server or something to authenticat users connecting to the APs?
Sorry if I sound a little noobish Wireless isnt my strong point.
Cheers.
Yes.  And here's the logic:
Flexconnect is good when you DON'T have any local WLC at the site.  This means that the AP will still go a WLC but to do so without overwhelming or monopolizing the WAN link.  Flexconnect was designed for this purpose.  Now, Flexconnect gets even better.  If in local mode, when a WLC or WAN link goes down, the APs go "dumb".  They just sit around and wait for the WLC to get back.   But with Flexconnect, when the WAN link or the WLC goes down the AP still operate like normal.  So the question is this:  If you have Flexconnect and the WLC and the WAN link goes down, how do you authenticate new user if you don't have any local authentication.  Remember your WAN link is down.  So this is why Flexconnect requires you have a local authentication server so when the WAN link is down, new users can get authenticated.
Ahhh i see, we do have a have a local authentication server, but would this explain why the APs completly dissassciate from the WLC and then rejoin? Or is there something else that is requred to be configured a long with flexconnect?
Your common denominator here is your WAN link, Telstra.
I know it's difficult to talk to Telstra when it comes to getting them to figure out why your APs get disconnected.  Heck, having dealt with them in the past, their immediate response is "it's not our fault, it is yours".  Telstra's motto is "the customer is ALWAYS WRONG".
Your APs loose contact to your controllers because their heartbeat gets "lost" or gets significantly delayed.
Flexconnect is a potential solution.  Another one is to put a small WLC, like a 2504, at each site.
Another solution is to investigate.
If you need to investigate, look for a pattern when this occurs.  Do the APs loose heartbeat during AU daytime/worktime or ALL the time?  Weekdays/weekends.  Blah, blah, blah ...
Before you go to Telstra, make sure you look at your network as well.  Make sure the link from your core switch and core routers to your WLC is working fine and there are no signs of congestions, line errors, etc.
Your APs do not have QoS enabled, do they?  I hope not.
Hi Leo,
I did some reading FlexConnect, I was wondering if there are ASAs in place will this affect FlexConnect? Would ACLs need to be put in place on the WAN providers side or port forwarding?
Cheers,
-Jake
since you are APs are joining the controller sometimes , there shouldn't be any kind of filters that might block the capwap data and cotnrol traffic.
Primarily the issue is with AP heartbeats getting lost.
You have to make sure about couple of things:
- Round trip latency is within the flexconnect guidelines
it shouldn't be more than 300 ms.
you can use the link latency feature on the flexconnect APs to make sure that you are adhering to the aforementioned guideline
wireless --> click the flexconnect AP  --> advanced --> enable link latency
hit apply
then go to advanced tab for that particular AP to see the figures.
- Make sure to prioritize the capwap traffic between the AP and the controller to avoid any delay when congestion happens across the wan link.
check the following link for flexconnect deployment:
http://www.cisco.com/en/US/partner/docs/wireless/controller/7.2/configuration/guide/cg_flexconnect.html#wp1241304
Please make sure to rate correct answers
Yeah... maldehne is right on... also don't look at the controller association latency because that is misleading in a way.  Thats cumulative and if you look at the screen shot from my FlexConnect AP, it has 3m 39s.  The AP is connected to the same switch that the WLC is connected to in my home lab.  Look at the local mode AP also.
FlexConnect
Local Mode
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I had a thought, would it be better to turn flex connect off on the APs that are onsite with the WLC? Its just a thought, plesae correct me if I am going off in a tangent.
Cheers
