Cisco AIR -OEAP 602I disconnect after long idle time.
JOHNSON CHIRRA
Hi Team,
I have configured OEAP 602i testing with the Corp SSID its working. I noticed that it is Corporate SSID not showing after long idle time at my home. once i have restart the device its working. Every day same issue.Kindly suggest any setting is require to avoiding the issue
Thanks & Regards,
Johnson
George Stefanick
First thing I would do is make sure the AP600 is still joined to the WLC. This will require you to log into the WLC and make sure you see it in the wireless tab. I would check the logs to see if it flapping. That would be the first step.
We have a large deployment of Ap600. We find the solution very reliable and easy to set up and deploy. I cant say we had one where the SSID just stops working.
Please rate helpful post!
www.my80211.com - Blog by a WiFi engineer for WiFi engineers
www.wifitraining.com/about-wifi/ - WiFi Training by hands on WiFi Engineers, Experts and Cisco Wireless VIPs
