Cisco AIR-PCI352 to AIR-LMC352 Conversion
sbreeding
Does anyone know if it is possible to use the card out of a PCI352 in a normal laptop slot? I pulled the card out, and it appears to not work when I insert it into the PCMCIA slot. It there a firmware flash that I can do, or am I just out of luck...
smalkeric
Level 6
Level 6
PCI352 is a pci bus (not pcmcia) card carrier with a pcmcia plug-in module. It has an external antenna.
The module part of the pci352 does not work when plugged into a pcmcia plug eventhough it's physically the same connector the same hardware, the firmware is different. I am not sure if it works by reflashing.But i guess it should work.
