Cisco Aironet 1100 connecting problems
thomasd007
Hi, we have a couple Cisco Aironet 1100 series wireless access points for users with PDAs that are having some issues with PDAs connecting. It seems that the PDAs will see other access points in the area and try connecting to them, then they will finally connect to our access point. The PDAs don't have any way to specify what access point to connect to, so does anyone know of a way to setup the access point itself to make the PDAs connect more reliably. The access point is mostly setup with defaults right now. Thanks for your time.
dixho
Level 6
Level 6
I need more information. Can you post the AP configuration please? I need to know the authentication type and encryption type. Also, what is the make and model number for the PDA and wireless adapter?
