Cisco aironet 1310 Outdoor access point
rustyk123
I am looking at outdoor access points, I want to stick with Cisco aironet, we currently have 6 of them that are 6 years old and running great, one has had a problem because of humidity, dried it out and relocated and we are good again.
I was looking at the Aironet 1310 Outdoor access point, but I can't find much information on it.  I am looking to see how many SSIDs can be setup, we currently have 2 one private, and one public, this is done with VLANS.  I am also looking at finding out about the power injector, it converts to coaxial cable, it has 2 RJ-45 and 2 Coaxial, does this mean if we get 2 access points, then I only need 1 power injector?
Thanks for any help you can give.
Amjad Abdullah
Rusty:
AP supports up to 16 SSIDs to be configured.
Multiple SSIDs with VLANs configuration is done almost the same way you do with current Aironet APs.
see here: http://tiny.cc/0qwnkw
You also need one power injector per AP. Each AP should use it's own power injector.
The two coaxial output in the power injector both are used to be connected to the AP (see below image).
The RJ-45 connectors in the power injector one of them is for Console connectivity and the other for network ethernet connectivity.
Check here: http://tiny.cc/7gxnkw
Amjad
Rating useful replies is more useful than saying "Thank you"
