Cisco Aironet 1530i Outdoor Access Point - Bridge Range @ 5Ghz
Mark Rigby
Greetings, id like to deploy some 1530i access points in bridge mode between two points located ~250m apart, however i'm unsure of the range these AP's will support using the internal antennas or whether the beam with is small enough to cover the distance, assume they will do several km but can anyone point me in the direction of a datasheet to confirm this please?
Edit: Think i may have answered my own question, internal antennas are omni's so probably looking at the external model!
Rasika Nayanajith
This link may be useful to you.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
Rasika
*** Pls rate all useful responses ****
