09-01-2020 06:12 AM - edited 07-05-2021 12:27 PM
Hi, I need to purchase one AP Aironet 1560 Series and I have WiSM2 WLC in my network, I need to make sure that WiSM2 WLC supports and compatible with Aironet 1560 Series, thanks
09-01-2020 07:09 AM
Check the compatibility matrix:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If you are running software version between 8.3.111.0 and 8.5 then it will be compatible.
Dont forget to rate helpful posts
Log in to Community
