ā02-19-2020 09:50 AM - edited ā07-05-2021 11:44 AM
I am installing the Cisco Aironet 1572EAC WAP and pg. 48 of the installation instructions points to 2 different caps to cover the AC power input. We are using PoE for the device so do I need to cover the AC input with Remke cap 75-0086 or the AIR-ACC15-AC-CAP=
ā02-19-2020 10:29 PM
If you are using PoE directly from a switch or powering via DC, then you will need to order AIR-ACC15-AC-CAP=.
Dont forget to rate helpful posts
ā02-20-2020 07:28 AM
I saw that too, and I guess I'm confused because it sounds like both caps are made to cover the same thing. So wouldn't either work? I already ordered the Remke cap before I re-read that part.
