Cisco aironet 1700 Ip assignment using CLI
jeffmaki1
Community Member
I am getting the error as shown below, How do I move forward and assign the IP address?
I am using cisco aironet 1700 series AP, Please help
*Mar  1 00:11:44.499: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:12:34.499: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:13:24.499: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP
5 Replies 5
Leo Laohoo
Is the AP going to be used with a controller or not?
No
tgcg
Community Member
I am getting the same with a number of 1702 APs (AIR-CAP17021-E-K6).  The 1702's all get an IP through DHCP and the WLC's IP via option 43 however the AP then reports it can't discover the WLC and then renews it's IP and starts the cycle again...
*Mar  1 00:02:59.547: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.10.2.50 obtained through DHCP
Not in Bound state.
*Mar  1 00:03:46.047: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:03:49.119: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.10.2.54, mask 255.255.255.240, hostname AP5897.bda2.f4e4
Translating "CISCO-CAPWAP-CONTROLLER.userdomain.intranet"...domain server (10.238.32.122)
*Mar  1 00:03:57.047: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.10.2.50 obtained through DHCP
Not in Bound state.
*Mar  1 00:04:43.547: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 00:04:46.619: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.10.2.60, mask 255.255.255.240, hostname AP5897.bda2.f4e4
On the Management interface of the WLC.
Do you have the 'Enable Dynamic AP Management', box checked?
Paste the info:
sh version from AP
sh sysinfo from WLC.
