CISCO Aironet 1702I series how to setup wireless AP without controller
mudassir.shah
Hello Friends,
I have bought new device CISCO Aironet 1700 series without controller, successfully connect and changed the mode to Autonomous. Configured all interface's like GigabitEthernet (0/1) and Radio. But interface are not pinging ? why
Now my question is , I want to setup device as wireless access point for internet usage of office clients, please guide me what settings are to be set to open GUI interface of device.
Mudassir Shah
Sr. Network Support Technology
bunnarot
Hi  mudassir.shah
I just done setup Aironet 1702i to standalone. i ask my friend to help too he send Firmware unanimous AP and i update to use interface.
pieterh
"Configured all interface's like GigabitEthernet (0/1) and Radio. But interface are not pinging"
-> please tell more about what you configured?
it may mismatch your local network settings
or reset the AP to factory settings
Step 1 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2 Press and hold the MODE button while you reconnect power to the access point.
Step 3 Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
it will allow the AP to retrieve an ip-address from your local DHCP server (if available) then you can access the AP using the DHCP address and a web-browser
the AP has a setup wizard that will perform a basic configuration to create a wlan and forward data to your local router for internet access
